Pressure constraint in laminar flow
Posted 18 gen 2023, 13:11 GMT-5 General, Computational Fluid Dynamics (CFD), Studies & Solvers Version 6.0 2 Replies
Hi all,
I'm trying to model dilute transport of a chemical species in laminar pipe flow. However, I keep getting the following error message:
"There is no feature constraining the pressure. A pressure constraint is required to specify the pressure level. Ignore this warning if the pressure is constrained using pointwise or weak constraints. - Node: Laminar Flow (spf)"
I specified the pressures at the inlet and outlet of the horizontal cylinder. Head loss is negligible. I've attached a zip file containing my simulation. Any and all help would be appreciated! Thank you
