Is there any model about performing transient analysis using Joule heating and thermal expansion physics in COMSOL4.2?
I tried transient solver on the Joule heating and thermal expansion physics in COMSOL4.2. My geometry is just a simple beam with injecting current at one port and ground at the other. There is always a error "Failed to evaluate the variable mod1.tem.DZ". But the problem is gone when I used just joule heating physics or thermal stress physics. Is there anything I need to notice when transient solver is used on the Joule heating and thermal expansion physics? Is there any model available? Thanks.
James
2 Replies Last Post 26 set 2012, 07:07 GMT-4
Andrea Ferrario COMSOL Employee
Posted: 1 decade ago 26 set 2012, 04:42 GMT-4
Hello James,
The problem you described has been solved in version 4.2a update 2. Please contact your local Comsol distributor to obtain a copy of the latest version (4.3). If you are using a university license, you may want to speak to your professor instead.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Hello James, The problem you described has been solved in version 4.2a update 2. Please contact your local Comsol distributor to obtain a copy of the latest version (4.3). If you are using a university license, you may want to speak to your professor instead. -- Andrea Ferrario Electromagnetics Group COMSOL AB
Posted: 1 decade ago 26 set 2012, 07:07 GMT-4
Hello James,
Andrea Ferrario
COMSOL AB
OK. Thanks a lot.
James
[QUOTE] Hello James, The problem you described has been solved in version 4.2a update 2. Please contact your local Comsol distributor to obtain a copy of the latest version (4.3). If you are using a university license, you may want to speak to your professor instead. -- Andrea Ferrario Electromagnetics Group COMSOL AB [/QUOTE] OK. Thanks a lot. James
