Heat transfer
Posted 22 set 2012, 03:29 GMT-4 Heat Transfer & Phase Change 1 Reply
I have a geometry of wall with several layers in it. Different layer has different thermal conductivity. The known parameters are only the thermal conductivities of different layers, thickness of each layers, and temperatures at outermost (higher temperature) and innermost wall (lower temperature i.e. there is thermal gradient between layer and heat flux occurs due to that). I want to evaluate the temperatures at different layer interface and heat flux. It usually happens in cold storage wall.
1 Reply Last Post 23 set 2012, 21:35 GMT-4
