about the field in the coil
Dear all ,
I am trying to excite the primary coil with current of 10 A , and need to test the magnetic field induced in the secondary coil , i excited the primary coil with current using single turn coil domain , i am not getting any field in secondary coil ..please let me know what is problem
Thanks in advance
kishore Naik Mude
2 Replies Last Post 19 set 2012, 13:22 CEST
Posted: 1 decade ago 19 set 2012, 12:40 CEST
There is a magnetic field in your second coil.
See results section, derived values.
You can also visualize it when adapting the color and data range of the surface plot to relatively small values.
There is a magnetic field in your second coil. See results section, derived values. You can also visualize it when adapting the color and data range of the surface plot to relatively small values.
Posted: 1 decade ago 19 set 2012, 13:22 CEST
thanks eric
kishore Naik Mude
thanks eric -- kishore Naik Mude
