Inverse heat conduction problem - determination temperature-dependent thermal conductivity
Posted 19 set 2012, 10:25 CEST Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.0, Version 4.2 2 Replies
I am interesting to solve an inverse heat conduction problem in order to determine the thermal conductivity using Comsol.
The study area is a block and I have the six boundary values and 50 temperature measurements in the area. I suppose that there is not heat generation and temperature doesn’t change (steady-state).
I would like to ask you if the above problem (the determination of thermal conductivity) can be solved using Comsol.
Where can I find more information that will help me with the above problem?
Thank you in advance,
George
George
2 Replies Last Post 19 set 2012, 15:55 CEST
