1D elements in 3D analysis
I have a cylinder of some solid material with a narrow central channel filled with presumably a fluid. The channel, connected to the "outside", transports heat and species to and from the solid by diffusion.
The channel is narrow and I am not interested in the temperature and concentration profiles over the cross-section of the channel. Using 1D elements would greatly reduce the mesh complexity. I think Ansys has such a feature. Is there a similar thing for COMSOL?
2 Replies Last Post 24 ott 2022, 10:16 GMT-4
Posted: 2 years ago 20 ott 2022, 13:46 GMT-4
Hello Ruben,
Yes, you are describing the Pipe Flow Module!
Jeff Hiller
Hello Ruben, Yes, you are describing the [Pipe Flow Module](https://www.comsol.com/pipe-flow-module)! Best, Jeff
Posted: 2 years ago 24 ott 2022, 10:16 GMT-4
Thanks Jeff! I will definitely look into it.
Regards, Ruben
Thanks Jeff! I will definitely look into it. Regards, Ruben
