Edgar J. Kaiser
Certified Consultant
3 years ago
14 ott 2022, 14:47 CEST
You may want to check this blog contribution: https://www.comsol.de/blogs/using-the-previous-solution-operator-in-transient-modeling/
I am not sure if the previous solution works in frequency domain studies. I used it successfully in time-dependent studies.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
3 years ago
17 ott 2022, 03:39 CEST
Hi Kaiser,
Thank you very much.
I'll give it a try.
Hi Kaiser,
I'll give it a try.
Kristian Ejlebjærg Jensen
COMSOL Employee
3 years ago
31 ott 2022, 13:31 CET
Which optimization solver are you using? Is it gradient based or not? The max/min operators are not supported for gradient based optimization.
3 years ago
7 nov 2022, 11:11 CET
Updated:
3 years ago
Hi Kristian,
Thank you for your reply, I didn't notice that, I used BOBYQA as my optimization solver, I remember this solver isn't based on gradient based optimization.
Also, I found a method that can achieve my goal perfectly, in the objective function I simply typed in "abs(Ztot)" which means absolute value of impedance, then in frequency domain step I only typed my goal frequency, for instance, 550 Hz, by this method, I can simply adjust the control varaibles to maximize my objective function.
Hi Kristian,
