Math operations with different solutions
Posted 5 set 2012, 13:08 CEST Heat Transfer & Phase Change, Results & Visualization Version 4.2 4 Replies
Hello. I hope someone can help me with this question.
Is it possible to operate with different post-processing solutions? For example, I want to obtain a ratio between a temperature field calculated with initial thermal parameters of the materials and the temperature field obtained with some parameters modified (with no changes in the geometry and the mesh). This way I want to obtain a surface plot to see where the temperature has decreased from the initial situation (ratio>1).
It seems this is not possible with Comsol, so I have tried to export both temperature fields to files (in spreadsheet and sectionwise formats) to operate them y Matlab, but these format don´t seem to be easy to use in Matlab.
Any suggestions, please?
Thanks in advance.
Thanks in advance.
4 Replies Last Post 6 set 2012, 20:23 CEST
