Define the displacement of a domain/surface relative to another domain/surface
Posted 25 ago 2022, 11:38 GMT-4 Studies & Solvers, Structural Mechanics, Physics Interfaces Version 5.6 1 Reply
I have a mechanical resonator (a mass hung by springs within a frame where the mass can resonate). The springs that hold the mass I want to compress. I do this now by having a small part of the frame (the slider), "slide" by applying a step displacement. The slider is not connected to the frame in any way.
This is where my problem arises because after having moved the sliders, I want to either rotate or translate the frame. This works, however, because the sliders aren't attached to the frame, they don't move with the frame (which is what I want). This leads me to my question.
Is there a way where I can define the displacement of a domain relative to another domain?
I've made a simplified model of my problem that hopefully helps to illustrate my issues. The springs are compressed, the mass is given a sinusoidal displacement (simulating the mass in resonance) and then the frame is moved in some way. The model shows that the sliders are fixed after the compression and not moving with the moving frame.
I someone could help me with this that would be great!
Thanks!
