geometric parameter sweep
Greetings everyone,
I'm running some stationary simulations using the MEMS module.
I would like to make a parametric sweep for a certain geometric variable.
The problem is that when changing this variable manually or automatically (sweep), the domains get messed up, e.g. materials assigned to domains get mixed up, the same occurs for the boundary and initial conditions, and all of this would have to be re-assigned manually.
My geometry contains one imported component (is it the cause of the problem ?)
Any suggestions on how this can be fixed ?
5 Replies Last Post 31 ago 2012, 02:18 CEST
Posted: 1 decade ago 30 ago 2012, 02:59 CEST
one rule with geometrical sweep is NOT to change topology, because then COMSOL need to reorder the entity ID's and that tend to go wrong
Hi one rule with geometrical sweep is NOT to change topology, because then COMSOL need to reorder the entity ID's and that tend to go wrong -- Good luck Ivar
Posted: 1 decade ago 30 ago 2012, 16:16 CEST
Create a selection by right-clicking the Geometry node and select Object Selection that will base the selection on geometry entities rather than domain numbers, and can help you specify exactly what selections are created in the final geometry, even if topology changes happen during the
sweep.
The Gecko Foot example demonstrates how to use this feature.
Model Library path: MEMS_Module/Actuators/gecko_foot
regards, Niklas
Create a selection by right-clicking the Geometry node and select Object Selection that will base the selection on geometry entities rather than domain numbers, and can help you specify exactly what selections are created in the final geometry, even if topology changes happen during the sweep. The Gecko Foot example demonstrates how to use this feature. Model Library path: MEMS_Module/Actuators/gecko_foot regards, Niklas
Posted: 1 decade ago 30 ago 2012, 17:38 CEST
...And for those without the MEMS Module, check out this link:
www.comsol.com/showroom/documentation/model/1434/
...And for those without the MEMS Module, check out this link: http://www.comsol.com/showroom/documentation/model/1434/
Posted: 1 decade ago 30 ago 2012, 18:58 CEST
Thank your everyone for your replies.
Thank your everyone for your replies. Regards,
Posted: 1 decade ago 31 ago 2012, 02:18 CEST
Hi Niklas
Thanks for the hint, I had noticed that when using selection goups (something I tend to do) COMSOL was far better to follow major changes in the geometry. So probably I should change my pre v4.2 learned "rule" of NOT changing topology, and now COMSOL also accept topology changes, that is great ;)
Hi Niklas Thanks for the hint, I had noticed that when using selection goups (something I tend to do) COMSOL was far better to follow major changes in the geometry. So probably I should change my pre v4.2 learned "rule" of NOT changing topology, and now COMSOL also accept topology changes, that is great ;) -- Good luck Ivar
