error
sir,
I got the following error.
Error: 7220
All variables solved for must be treated in at least one segregated solver step.
what to do for this.
I declare two segregated groups each for one physics
1 Reply Last Post 3 ago 2012, 10:44 CEST
Posted: 1 decade ago 3 ago 2012, 10:44 CEST
tis happens if you have a solver sequence and you have modified it somehow, and later added a new dependent variable that COMSOL has not managed itself to add to the solver sequence. Check all your dependent variable names, and see where they appear in the segregated solver list, one at least is mssing, you need to add it manually, or to delete and regenerate xour solver sequence from scratch, with the risk of loosing all your postprocessing set-up (use as last resort)
Hi tis happens if you have a solver sequence and you have modified it somehow, and later added a new dependent variable that COMSOL has not managed itself to add to the solver sequence. Check all your dependent variable names, and see where they appear in the segregated solver list, one at least is mssing, you need to add it manually, or to delete and regenerate xour solver sequence from scratch, with the risk of loosing all your postprocessing set-up (use as last resort) -- Good luck Ivar
