How to induce temperature-dependent variable in HTS cable model
Posted 28 lug 2012, 10:34 GMT-4 Heat Transfer & Phase Change Version 4.2 1 Reply
                                                    I am new to COMSOL, and i am trying to model of ac losses in HTS cable. Firstly, i have already implemented T-independent model, which assumes Jc and alpha as constant. In this assumption, the comsol can work well. However, now i need to consider the effects of temperature on Jc and alpha. I simply change the Jc and alpha from parameters to variables. It encountered a problem:
Feature:Time-Dependent Solver1(sol1/t1)
Error: Failed to evaluate expression.
Checking the Error, it said
Attempt to evaluate real logarithm of negative number.
- Function: log
Failed to evaluate temporary symbolic derivative variable.
However, i have clearly defined these variables in Model1. Hope someone can help me.
- Function: log
1 Reply Last Post 6 ago 2012, 09:53 GMT-4
