More parameters in Global Definitions
Hi, I doing an acoustic simulation with Comsol (acoustic room). I would have more studies for the same geometry model in the same file. So I adding in Global Definitions two list of parameters (Parameters 1 and Parameters 2) with very different type of data. With Study 1 I use Parameters 1, while with Study 2 I should use Parameters 2 only. How can I link Parameters 2 with Study 2 instead Parameters 1? Thank you.
2 Replies Last Post 14 feb 2022, 16:48 CET
Posted: 4 years ago 10 feb 2022, 17:56 CET
Jessica,
a manual way to do that might be to have the two lists Parameter1 and Parameter2 with identical parameter names inside each. When running study 1 you disable Parameter2, when running study 2 you disable Parameter1.
In case you want to do it fully automtically you will need to add some little JAVA code in model methods.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Jessica, a manual way to do that might be to have the two lists Parameter1 and Parameter2 with identical parameter names inside each. When running study 1 you disable Parameter2, when running study 2 you disable Parameter1. In case you want to do it fully automtically you will need to add some little JAVA code in model methods. Cheers Edgar
Barry Ren Imaging physics
Posted: 4 years ago 14 feb 2022, 16:48 CET
great to learn this trick!
