Water evaporation problem
Posted 6 gen 2022, 21:55 GMT-5 Heat Transfer Version 5.4 1 Reply
Regarding the evaporative cooling case of water** (the document version is 5.4). The result processing in the file uses the surface integration function in the derived value to calculate the amount of evaporated water. The simulation result integrates the total normal water vapor flux to get -1.4857E-4 (kgmin/s), but the case PDF file shows that about 1.6g of water has evaporated. This is inconsistent with the simulation results, I hope to get relevant answers, thank you very much.
