Magnetic flux density
in the model attached i excited the coil by single turn coil domain , but i am getting only the magnetic flux density on first coil only , not reaching the second coil can any one pls solve the problem , i am not bale to attach the model as it is very high size
kishore Naik Mude
2 Replies Last Post 8 mag 2013, 20:14 CEST
Hello kishore naik
Posted: 1 decade ago 8 mag 2013, 19:54 CEST
there is no model attached!
Delete the solver and the solution and attach a clean file. Solution needs a lot of memory but not the model, usually!
Otherwise, no one can help!
Hi there is no model attached! Delete the solver and the solution and attach a clean file. Solution needs a lot of memory but not the model, usually! Otherwise, no one can help!
Posted: 1 decade ago 8 mag 2013, 20:14 CEST
You may click "edit", then choose "clear mesh", "clear result". The size of file will be smaller enough to upload.
