Flatten a cylindrical surface
My model has a cylindrical geometry and is running a heat transfer simulation. I want to look at the streamline on cylinder surface. I'm wondering if it's possible to cut the surface and flatten it into a 2D temperature plot?
Thank you!
Lillian
1 Reply Last Post 2 dic 2021, 11:20 CET
Magnus Ringh COMSOL Employee
Posted: 3 years ago 2 dic 2021, 11:20 CET
Updated: 3 years ago 2 dic 2021, 11:42 CET
Hi Lillian,
You can do this by adding a Surface dataset that takes your Solution dataset for the 3D heat transfer simulation as its input. Select the cylinder surface or surfaces to include in the 2D surface. You can then use that Surface dataset in a 2D Plot Group and add a Streamline plot to that plot group.
Magnus
Hi Lillian, You can do this by adding a Surface dataset that takes your Solution dataset for the 3D heat transfer simulation as its input. Select the cylinder surface or surfaces to include in the 2D surface. You can then use that Surface dataset in a 2D Plot Group and add a Streamline plot to that plot group. Best regards, Magnus
