Beam cross sections
Posted 15 set 2021, 10:25 GMT-4 Structural & Acoustics Version 5.4 0 Replies
I'm trying to model a 2D structure composed of beam elements. I have to choose a rectangular cross-section. The thickness in plane chosen is 4 mm whereas the thickness in the z direction is much greater and is of 205 mm. I would like to know if it is numerically correct and reasonable to have such a difference between the two dimensions? Is there a certain ratio to respect while choosing a cross-section for the beam elements? If yes, what's the limitation?
Thank you in advance.
Hello Monzer Al Khalil
