How to save deformed geometry so that it can be used as new initial geometry for another analysis ?
Hi.
I am looking the ways to save the deformed geometry at the end of analysis, and i would like to use it as a completely new initial geometry for further analysis, by clearing out the previous solution.
I would appreciate any help ! thanks !
/krishna
5 Replies Last Post 25 dic 2013, 00:05 CET
Posted: 1 decade ago 22 giu 2012, 12:18 CEST
have you read about the feature of the Data Set - Solution (right click) Re-mesh deformed configuration, can this do what you want ?
Hi have you read about the feature of the Data Set - Solution (right click) Re-mesh deformed configuration, can this do what you want ? -- Good luck Ivar
Posted: 1 decade ago 10 lug 2012, 13:05 CEST
I tryed this too, but what I got was the original mesh, I then stored the mesh, but a stored geometry can't be remeshed!! When I then continue computing I get a solution that looks relatively good but is still in the non deforemed geometry!!
I attached the file!
Thanks for Helping!!
Andreas
Hi, I tryed this too, but what I got was the original mesh, I then stored the mesh, but a stored geometry can't be remeshed!! When I then continue computing I get a solution that looks relatively good but is still in the non deforemed geometry!! I attached the file! Thanks for Helping!! Andreas
Posted: 1 decade ago 8 apr 2013, 00:05 CEST
I am unable to save deformed geometry too (C'l 4.3a)! In fact the tutorial in User Guide regarding the same (Sub-Chapter on "Remeshing a Deformed Geometry—A Quick Example") did not work at my end (the last section where you put instruction for the initial condition to come from Solution 2).
Posted: 1 decade ago 22 mag 2013, 02:48 CEST
I agree the "Remeshing a Deformed Geometry—A Quick Example" tutorial is bugging in the end.
Can anyone update us on this problem?
Thank you
Nicolas
Hi, I agree the "Remeshing a Deformed Geometry—A Quick Example" tutorial is bugging in the end. Can anyone update us on this problem? Thank you Nicolas
Posted: 1 decade ago 25 dic 2013, 00:05 CET
Hi there,
still no solution on this one? I am starting to work with deformed geometries, having trouble with the example from the user's guide as well.
Did anyone figure out what is the problem, yet?
Best
Christian
Hi there, still no solution on this one? I am starting to work with deformed geometries, having trouble with the example from the user's guide as well. Did anyone figure out what is the problem, yet? Best Christian
