contact pair
Posted 11 ago 2021, 00:24 GMT-4 Electromagnetics, Heat Transfer & Phase Change, Structural Mechanics Version 5.4 0 Replies
i am designing a contact shaped structure as in relays, designed as lookalike the shape of the contacts in relay. i want to apply force or load on the movable part of the contacts which has to move and touch the stiffer part contact . (both are similar structured) 1. want to measure the pressure applied by the movable part to the fixed part contact surface 2. Want to measure the intendation of depth to the fixed part of contact surface made by the load or force over the movable part 3.Want to measure the temperature 4. want to know how to apply current or voltage as source to the contact and to measure the heat, current or voltage over the surface of the contact 5. want to measure the displacement made by the applied force or load , similarly the deformation of the contact if any I would be very grateful to you if you give any ideas or procedures to implement these and to find these parameters. Hoping to get a positive reply. Thanks in advance. with regards M.Thanigaivelraja
Hello Thanigaivelraja Mohandass
