Two vertical plates cooling by a fan. Doubts about the use of Comsol.
Posted 14 giu 2012, 06:34 GMT-4 Fluid & Heat Version 4.2a 1 Reply
I am a new user in Comsol Multiphysics and I need to use the program for my thesis. The item to study consists of two plastic vertical-parallel plates. The left one generates 100 W and also there are radiation and convection due to the difference of temperatures. The right one is only a plastic plate which is used like a wall. Between both sides there is a fan which cooling the left side. First, I did an analytical calculation and I calculated the convective heat transfer (due to natural convection and forced convection because of the fan), h=13 W/m2*K, and the velocity needed by the fan, v=2 m/s
After this, I tried to build the model using Comsol but I have numerous doubts:
1. I don’t know if is better to used “Conjugate heat Transfer” or “Heat transfer in solids” taking into account that I have convection and radiation. I used “Heat transfer in solids”
2. I don’t know if I defined the contribution of the air that produces the fan in good way (I used another physic: laminar flow) and I introduce the data calculated before (h=13 W/m2*K, v=2m/s)
3. To introduce the convection I used “heat flux”. Also, I don´t know how to show that the air is at 323 K but the wall in left side is at 343K, because in heat flux, q=h (Text-T), I need to introduce the temperature Text=343 K and the heat flux contributes with: Temperature WALL 1, and in Temperature WALL 1 I need to introduce the temperature T. But, the temperature of WALL 1 is 343 K again, isn’t it???So, I don´t know how to show this effect.
4. In model inputs, I don’t understand the difference between “contribution of temperature (ht/ht)” or “user defined”. In my case, what would I have to use??
If anyone can help me I will be really grateful to you.
I didn't introduce the radiation because I wanted to see first the result of convection.
I add the simulation by Comsol.
Thanks.
Thanks.
1 Reply Last Post 14 giu 2012, 07:31 GMT-4
