Calculating acoustic reflection and transmission coefficient
I am profiling the refractive index of a materials with custom shapes for designing a acoustic metamaterial unit. The reflection coefficient and the transmission coefficient, mathematically can be derived as R = P(reflected)/P(incident) and T = P(transmitted)/P(incident). Which in COMSOL is R = acpr.p_s/acpr.p_b and T = acpr.p_t/acpr.p_b. But, in the application 'Acoustic Reflections off a Water-Sediment Interface' they demonstrate using Pin instead of acpr.p_b. Is there a reason to use Pin instead of acpr.p_b? Because I get non-physical values for using acpr.p_b (i.e. R>2).
Thank you. Akki.
1 Reply Last Post 19 ago 2021, 10:29 CEST
Acculution ApS Certified Consultant
Posted: 4 years ago 19 ago 2021, 10:29 CEST
In 'Acoustic Reflections off a Water-Sediment Interface' is exactly the background pressure. So if you don't get that, it could indicate that you are not using Pin as input in your background field.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
