conducting sphere in a uniform electrical field
HP Doctoral student, Uppsala University
I am new to COMSOL and trying to simulate field enhancement of sphere surface when a conducting sphere is in a uniform electric field.
I used electrocstatic physics (2D) and gave +100V for left boundry and -100V for right boundry to generate an uniform field. In between these two boundaries, sphere is placed.
According to analytical solution, the value of electric field at the poles of sphere should be 3 times of uniform/background electric field. But I can not get that answer and the field enhancing factor varies with radius in my simulation. What would be the mistake?
I would really appreciate it if you can comment on this matter. Simulation is attached herewith
2 Replies Last Post 30 giu 2021, 11:32 CEST
Posted: 4 years ago 29 giu 2021, 21:39 CEST
Updated: 4 years ago 29 giu 2021, 21:41 CEST
As soon as I opened your model, I noticed a big problem with it. Your 2D model is a simple X-Y plane 2D model. It is NOT an axisymmetric (R-Z) 2D model. So you are not modeling a sphere at all! The circle in your model is geometrically representative of an infinite cylinder (with its axis out of the page). This is rather different, of course, than a sphere. For the latter, you need to use an axisymmetric 2D geometry. Anyway, that's as far as I checked, before writing this reply. So you should fix that major error in your model first, then see if there are any other problems to deal with. Good luck. :)
As soon as I opened your model, I noticed a big problem with it. Your 2D model is a simple X-Y plane 2D model. It is NOT an axisymmetric (R-Z) 2D model. So you are not modeling a sphere at all! The circle in your model is geometrically representative of an infinite *cylinder* (with its axis out of the page). This is rather different, of course, than a sphere. For the latter, you need to use an axisymmetric 2D geometry. Anyway, that's as far as I checked, before writing this reply. So you should fix that major error in your model first, *then* see if there are any other problems to deal with. Good luck. :)
Posted: 4 years ago 30 giu 2021, 11:32 CEST
Dear Robert Koslover,
Thank you very much for the commect.
It works correctly.
Dear Robert Koslover, Thank you very much for the commect. It works correctly.
