5 giu 2012, 16:17 CEST
if you define your solid as "Heat Transer in Solid" domain node, you can add a Wall with noslip or slip conditions, as you are using NITF with heat coming from the fluid, but as a separate wall node due to the positions of the nodes and the override feature of nodes farther down in the tree
5 giu 2012, 16:44 CEST
Hello Ivar,
Do you mean I have to exclude my solid plate out of "ntfl" and include it in "Heat transfer in solids"?
Then I will be able to use wall condition in NITF? Or in HTiS?
Thank you!
Hello Ivar,
Thank you!
5 giu 2012, 20:42 CEST
N,o what I'm saying is that when you open a NITF physics with fluid flow as heat source, you get a given number of Default nodes, you need to add a Heat Transfer in Solid domain node to define your "solid" part, then you can add a wall between the fluid and the solid.
But that is also what I see in your model, so I do not fully understand what your are missing
6 giu 2012, 11:50 CEST
Hello Ivar,
what I`m missing is the definition of the wall for the solid part, if only I could use it somehow, that would be great. I had an idea about a small layer between the solid and liquid parts, so I could define the concact pair/identity pair, but I had problems with temperature. With this layer I lose my heat transfer.
Is it possible in Comsol to make something like that?
Thx in advance!
Hello Ivar,
Thx in advance!
6 giu 2012, 22:11 CEST
then use Assembly mode, this means that all boundary are dedoubled, and YOU the user must define all continuity pairs physics (one pair per physics). This allows you also normally to define a thermal resistive layer (or I was it this case that was announced for 4.3, I cannot remember just now) At least try it. But d not forget to link all physics at the identity boundary
