Robert Koslover
        Certified Consultant
                                4 years ago
                                16 giu 2021, 13:12 GMT-4
                        Updated:
                                4 years ago
                                17 giu 2021, 10:35 GMT-4
                                                    This is a Comsol Multiphysics forum.  Are you using Comsol Multiphysics?  You can do a lot of MATLAB operations within Comsol Multiphysics, but for MATLAB support, see the links at: https://www.mathworks.com/matlabcentral/?s_tid=gn_mlc or look in your MATLAB help system.
Added later:  I've begun to wonder if I may have misunderstood your problem.  I initially assumed that you sought to plot a curve/arc (just as you said), but did you really seek to create/build a geometric curve/arc (a 1D geometry structure) within a 3D Comsol working geometry, and specifically to do so by means of Matlab commands (e.g., via LiveLink for Matlab) rather than directly by Comsol's GUI?  The difference in meaning here is substantial: In one case, you are simply plotting a mathematical curve for you to look at.  In the other case, you are creating/building a geometric object.
Added later:  I've begun to wonder if I may have misunderstood your problem.  I initially assumed that you sought to *plot* a curve/arc (just as you said), but did you really seek to create/build a *geometric* curve/arc (a 1D geometry structure) within a 3D Comsol working geometry, and specifically to do so by means of Matlab commands (e.g., via LiveLink for Matlab) rather than directly by Comsol's GUI?  The difference in meaning here is substantial: In one case, you are simply plotting a mathematical curve for you to look at.  In the other case, you are creating/building a geometric object.
                                Robert Koslover
                                4 years ago
                                17 giu 2021, 13:37 GMT-4
                                                    See note added later, above.
