Comsol - Error in using a function to set the boundary condition dynamically in a program
Posted 23 lug 2009, 05:33 GMT-4 Version 4.0 2 Replies
I have encountered a problem in using self-written function to set the boundary condition of a heat conduction problem. The following is the part of generated code for setting the intial, boundary conditions and material properties:
str_qb = 'sin(t*x*y)';
bnd.g = {0,0.005,str_qb};
bnd.ind = [1,1,2,3,1,1];
appl.bnd = bnd;
clear equ
equ.init = 55;
equ.c = 0.0145;
equ.f = 0;
equ.da = 0.004108;
equ.ind = [1];
appl.equ = equ;
fem.appl{1} = appl;
fem.border = 1;
fem.units = 'SI';
Running the program, it works and I obtained the computation results!!!
However, after I commented "str_qb = 'sin(t*x*y)';" and replaced the code "bnd.g = {0,0.005,str_qb};" with "bnd.g = {0,0.005,'qb_fun(t,x,y)'};", where qb_fun(t,x,y) is a function defined by
function VI = qb_fun(t,x,y)
VI = sin(t*x*y);
, the program crashed after running. Error message is displayed as follows:
??? Java exception occurred:
Exception:
com.femlab.server.MlError: Error using ==> mtimes
Inner matrix dimensions must agree.
(rethrown as com.femlab.jni.FlNativeException)
Error in callback
Stack trace:
at callback.cpp, row 113, ()
at com.femlab.solver.FlSolver.femTime(Native Method)
at com.femlab.solver.FemTime.run(SourceFile:69)
at com.femlab.server.FlRunner.run(SourceFile:120)
at com.femlab.server.MlProgressDlg.runAndWait(SourceFile:142)
at com.femlab.server.FlRunnable.runAndWait(SourceFile:69)
Error in ==> femsolver at 225
solobj.runAndWait(report, 'Solution Progress', loopTime);
Error in ==> femtime at 61
varargout = femsolver(mfilename,'FemTime',varargin{:});
Error in ==> fp_model at 85
fem.sol=femtime(fem, ...
I am so confused with the result (I have only set the same boundary condition by means of different ways). I'd greatly appreciate it if some comsol expert can help me find the error. Thanks a lot.
Windson
appl.bnd = bnd;
clear equ
equ.init = 55;
equ.c = 0.0145;
equ.f = 0;
equ.da = 0.004108;
equ.ind = [1];
appl.equ = equ;
fem.appl{1} = appl;
fem.border = 1;
fem.units = 'SI';
VI = sin(t*x*y);
Exception:
Error in callback
Stack trace:
Windson
2 Replies Last Post 30 lug 2009, 07:01 GMT-4
