22 mag 2012, 08:45 CEST
but one should dissociate periodic heat and flow conditions. For me if you set up periodic heat equations you are transaforming your 2D problem into a 1D problem, in stationary you will en up with straight T contours, no ?
One can use symmetric heat conditions but this does neihter allow a heat flow perpendicular to the plane, so not valid for the fluid flowing
22 mag 2012, 10:45 CEST
Actually yes this exactly means that the problem is now 1D. I have seen the manual describing the use of periodic boundary conditions in 3.5(a) but they have used a Dirichilet boundary condition on temperature at the inlet while a convective flux at the exit the b.c for k,e and v are set to periodic however. If I use the same conditions for heat transfer in my problem which is simply a turbulent pipe flow with constant heat flux acting at the wall I am not getting accurate results for the Nusselt number however I am getting good result for the friction factor. I am confused regarding what boundary conditions I can use to model the heat transfer in the liquid??? Moreover I cannot find how to implement the periodic boundary conditions in comsol 4.2 as there is no page available for source vertices and destination vertices also how to add a variable in the solver groups if the variable is defined as an ODE in comsol 4.2?
Thanks for your suggestions
22 mag 2012, 10:48 CEST
I am sorry but what do u mean by disassociate the periodic heat and flow conditions how can one achieve this?
22 mag 2012, 11:26 CEST
I cannot remeber how it was back in 3.5, but in v4 you have 2 periodic boundary conditions for conjugated heat transfer (NITF) one per physics, you do not need to set a heat periodic boundary condition, even if you use flow periodic boundary conditions. But perhaps 3.5 did not distinguish ?
