Jacobian evaluation argument of realdot must be 0, 1, or -1
Hello I am a new comsol user 5.5 While analysing the photonics crystal I am facing "Jacobian evaluation argument of realdot must be 0, 1, or -1"
It would be nice if you can help me.
1 Reply Last Post 3 mar 2021, 15:06 CET
Magnus Ringh COMSOL Employee
Posted: 4 years ago 3 mar 2021, 15:06 CET
Hi Amartya,
This error occurs because you are using the optional third argument to the realdot operator in in an unintended way. From the COMSOL Multiphysics documentation:
realdot(a,b,jaclevel)
The jaclevel argument controls Jacobian contributions of the realdot(a,b) operator and can have the following values:
  • −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study
  • 0: no Jacobian contributions
  • 1: always Jacobian contributions
In your model, you have defined the variable nEz as intop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A, which is an incorrect use of the syntax with three input arguments.
Magnus Ringh
Hi Amartya, This error occurs because you are using the optional third argument to the `realdot` operator in in an unintended way. From the COMSOL Multiphysics documentation: `realdot(a,b,jaclevel)` The `jaclevel` argument controls Jacobian contributions of the `realdot(a,b)` operator and can have the following values: * −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study * 0: no Jacobian contributions * 1: always Jacobian contributions In your model, you have defined the variable `nEz` as `intop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A`, which is an incorrect use of the syntax with three input arguments. Best regards, Magnus Ringh
