Particle tracing+ force calculation
I want to calculate the particle trajectory resulted from fluid flow in a magnetic field based on the following equation:
m*dV/dT= a*dB/dx+ b(V-u)
where B, u and V are magnetic flux density, fluid velocity and particle velocity.
I have simulated the magnetic field (mf) and flow field (laminar flow, spf).
to calculate the trajectories, I have added "Particle tracing for AC/DC" physics and included a "force" node in it.
My question is:
How should I write the right hand side of above equation in the force node?
Can I write:
dB/dx= d(mf.normB,x)
V-u=d(qx,t)-u
Thank you for your reply
0 Replies Last Post 26 apr 2012, 15:13 CEST
Hello Mohammad Goharkhah
