Coupling Particle Tracing For Fluid Flow and Matlab Function
Hi, all,
I am curious to couple particle tracing for fluid flow and matlab function.
I am testing the simple model. My geometry of the model is 1m along x-direction by 1m along y-direction. In the geometry, I release 121 particles. There are 11 particles along x-axis with 0.1 intervals from 0 to 1 and 11 particles along y-axis with 0.1 intervals from 0 to 1. So, there are 121 particles in the square (1m by 1m) geometry.
After releasing the 121 particles, I am trying to count the 121 particles using Matlab function. In this process, I need to transfer particle position components (qx and qy in Comsol) from Comsol to Matlab. I use the below Matlab code.
function test_function = test_function(qx,qy)
[p,q] = size(qx);
n = p * q ;
X = reshape(X, n,1);
Y = reshape(Y, n,1);
test_function = ones(n,1) .* n;
end
The expected value is 121. But the result in Comsol using above Matlab code is 11.
I hope you can tell me why this result, that is 11, came out. If you can not tell me it, would you tell me alternative method to count the particles. I attach the simple model.
Thank you in advance.
Changyeol
0 Replies Last Post 4 feb 2021, 13:06 CET
Hello Changyeol Lee
