2 decades ago
23 gen 2010, 09:41 CET
well if you want to apply an acceleration load (i.e. a "space-craft launch load") you typically apply an acceleration field, in the harmonic mode (equivalent to apply a gravity acceleration field as for a static gravity sag analysis:
define constants:
G0= 1[lbf/lb] or just = 9.81 [m/s^2]
gravity sag in "smsld":
static mode, Load on subdomain Fz = G*rho_smsld
define a function
Acc (freq) = amplitude spectrum of your acceleration over desired frequency domain
In harmonic mode: parameter "freq" from 10 .. 500 Hz with TBD defined resolution
apply sub-domain load F = acc(freq)*rho_smsld
and off you go. Do you catch tha analogy with the ravity field case at feq=0 (i.e. static) ?
Its easy no? once you think about it, just apply your physics, that is what COMSOL is about, but you do not have all your physics predefined, as in most other FEM codes, this gives you far more freedom and allows to do thing not easily possible before
define constants:
define a function
29 ott 2014, 08:44 CET
Dear Ivar,
How to apply acceleration in Time-domain analysis. I also understand 'gravity sag in "smsld"'
RUBAN SUGUMAR
Dear Ivar,
RUBAN SUGUMAR
30 ott 2014, 22:02 CET
you need to be more precise: what kind of acceleration ?
Gravity = volume force as "rho*g_const" ?
rotational acceleration, boundary forces ...
In fact normally you do not apply directly an acceleration but rather you define a load of some kind of the type "rho*a" on each element dx*dy*dz of a domain or boundary
And do you accelerate the fixed boundary ? if so you have to check your equation because fixed and acceleration is not really compatible ...
9 years ago
17 nov 2016, 10:36 CET
hi
I am trying to check the result after applying g in piezoelectric energy harvester kindly help i am very new to comsol
hi
