Robert Koslover
Certified Consultant
5 years ago
15 dic 2020, 23:06 CET
Updated:
5 years ago
15 dic 2020, 23:14 CET
Perhaps you could post your model to the forum?
In a 3D model, have you considered employing a cylinder that is modeled as centered within a cylindrical computational volume, where your scattering cylinder is continuous from one computational end-cap boundary to the other, and then making use of Floquet boundary conditions on the end-cap faces (i.e., those perpendicular to the cylinder axis), so as to effectively extend the cylinder to infinity? (I also wonder if you might even be able to get away with simple scattering boundary conditions, in this case.)
5 years ago
17 dic 2020, 17:19 CET
Updated:
5 years ago
19 dic 2020, 09:57 CET
Thanks for your reply. It is 3D model. I have attached it for you.
Robert Koslover
5 years ago
17 dic 2020, 17:48 CET
I haven't taken the time to understand your whole model, but I can see that your electric field and k vector are both in a plane perpendicular to the axis of the cylinder. This makes your problem easier! Combined with the fact that you are interested in an infinitely long cylinder, this means you should probably do this whole problem in 2D, representing the cylinder by a circle (the effectively-infinite cylinder would be perpendicular to your 2D plane). So I encourage you to attack the problem in 2D. If that works well, you can consider more general wave incidence conditions in a 3D model.
I haven't taken the time to understand your whole model, but I can see that your electric field and k vector are both in a plane *perpendicular* to the axis of the cylinder. This makes your problem easier! Combined with the fact that you are interested in an infinitely long cylinder, this means you should probably do this whole problem in 2D, representing the cylinder by a circle (the effectively-infinite cylinder would be perpendicular to your 2D plane). So I encourage you to attack the problem in 2D. If that works well, you can consider more general wave incidence conditions in a 3D model.
5 years ago
17 dic 2020, 17:50 CET
Ok, I will try it in 2D.
