Regarding contour plot levels setting
Posted 22 mar 2012, 05:04 GMT-4 1 Reply
When i am doing the postprocessing of data using contour plot, COMSOL allow me to have two option on the level, by default it use 20 number of levels in my case(as attachment 1) to represent the magnitude, but when i cannot see contour, then i change it to manual level (as attachment 2) use range(0,5,20).
I thought it is fine for long.But today i present it to my colleague, they ask me a question, what is your legend bar means?is it the highest is only 20?
May i know why i change level, the magnitude of bar also change accordingly?or i do something wrong?
I think is because i do not understand contour level plot
I find Documentation but it only teach how to do it.
"Under Levels, select an Entry method—Number of Levels or Levels for the contours.
- If Number of Levels is selected, enter the total number of levels in the Total levels field (the default is 5).
- If Levels is selected, enter the values for the contour Levels or click the Range button () to "
Any idea sharing?
Hello Chiwei Ong
