Terminal Falling Velocity of a sand garin (tutorial)
Hi everyone...
Could someone please explain me why you add the GLOBAL VARIABLE X : X t - Xdo t. ?
The physics of the problem only state the necesity to establish the equation
Xdo t: Xdo tt-(F_z+F_g)/m_grain.,
which corresponds to the Ordinary Differential Equation:
(m_grain) * (Xdo tt) = (F_g+ F_z)
or
(F_g+ F_z)/(m_grain) - (Xdo tt) = 0 ; as is supossed to be entered in the software
The systems uses cylindrical coordinates so there is no conflict in x,y,z,t or X,Y,Z,T.
Thanks for your help on beforehand
Kind regards
1 Reply Last Post 28 gen 2017, 22:57 CET
Hello Clotario Tapia
Posted: 9 years ago 28 gen 2017, 22:57 CET
The ODE below can be removed from the model without affecting the solution.
falling_sand.mph > Model 1 > Laminar flow > Global Equations
Xt - Xdot = 0
However, if you * do * include the ODE for "X" in the Global Equations, then you have the opportunity to plot the position of the grain particle in the z direction (denoted by the variable "X"). For example, you can plot "X" vs. time to see the position of the grain as a function of time.
See also the related link below
www.comsol.com/community/forums/general/thread/46937
-DW
Hello, The ODE below can be removed from the model without affecting the solution. falling_sand.mph > Model 1 > Laminar flow > Global Equations Xt - Xdot = 0 However, if you * do * include the ODE for "X" in the Global Equations, then you have the opportunity to plot the position of the grain particle in the z direction (denoted by the variable "X"). For example, you can plot "X" vs. time to see the position of the grain as a function of time. See also the related link below https://www.comsol.com/community/forums/general/thread/46937 -DW
