15 feb 2012, 20:50 CET
Hi!
Study 2 should have some solved value for flow. Now it is using initial expression. Change Solver 2 => Dependent Variables => Method => Initial expression to solution and select Solution to Solver 1.
Best regards
Tero
Hi!
Best regards
Tero
15 feb 2012, 22:06 CET
Hi Tero,
That worked, thank you.
Do you know if there is a way to change the properties of the dilute species?
Thanks!
MRW
Hi Tero,
Thanks!
MRW
16 feb 2012, 17:35 CET
Hi!
What do you mean by changing properties? Changing bulk material or diffusion?
Br Tero
Hi!
Br Tero
17 feb 2012, 15:46 CET
I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics.
Thanks!!
Thanks!!
17 giu 2012, 19:14 CEST
The diffusion coefficient (D) is the only parameter that you can change. Please try it. I also do some research on this aspect. I am also a new one....
Thanks!!
[QUOTE]
Thanks!!
[/QUOTE]
