How to fix the shape of a boundary
In my simulation, one of the boundaries are evolving with time due to creep. Is it possible to fix the shape of the boundary? (thus the displacement of the boundary in the moving direction is uniform for a flat boundary).
Thank you very much!
3 Replies Last Post 17 feb 2012, 07:57 CET
Posted: 1 decade ago 11 feb 2012, 10:18 CET
yes mostly, but you need to write out some equations i.e. by enforcing/prescribing some preferred directions or normal or Force/pressure normals
Hi yes mostly, but you need to write out some equations i.e. by enforcing/prescribing some preferred directions or normal or Force/pressure normals -- Good luck Ivar
Posted: 1 decade ago 17 feb 2012, 01:00 CET
Hi, Ivar,
Thanks a lot for your suggestions. I am not quite following them though. Did you mean I can write out some equations like those with the PDE module? Would you please go a little more specific? I really appreciate it.
Hi, Ivar, Thanks a lot for your suggestions. I am not quite following them though. Did you mean I can write out some equations like those with the PDE module? Would you please go a little more specific? I really appreciate it. Best regards,
Posted: 1 decade ago 17 feb 2012, 07:57 CET
if you define "Prescribes Deformation" e.g along X only of a plane in Y,Z, and enter a number the deformation will be constant in X, but you can write X0[m]*sin(2*pi*fy*Y) and force a sinus deformation along Y with amplitude along X.
Then its only your imagination that is the limit.
One thing, in "Solid" physics, take car if you refer the deformation to the material frame X,Y,Z,R or to the deformed spatial frame x,y,z,r. The latter makes the system non linear (then hit also the solver tick mark non linear geometry (this has changed from 3.5 to 4 to 4.2a, in the last version x and X are different but x=X+u only if you select the tick mark in the SOLVER section (see the doc on the "Frames")
Hi if you define "Prescribes Deformation" e.g along X only of a plane in Y,Z, and enter a number the deformation will be constant in X, but you can write X0[m]*sin(2*pi*fy*Y) and force a sinus deformation along Y with amplitude along X. Then its only your imagination that is the limit. One thing, in "Solid" physics, take car if you refer the deformation to the material frame X,Y,Z,R or to the deformed spatial frame x,y,z,r. The latter makes the system non linear (then hit also the solver tick mark non linear geometry (this has changed from 3.5 to 4 to 4.2a, in the last version x and X are different but x=X+u only if you select the tick mark in the SOLVER section (see the doc on the "Frames") -- Good luck Ivar
