How to get the first time derivative of defined variables?
I defined "rho_E" as charge density, its unit is C/m^3. when I coupled the Electric Current, the Current source(A/m^3) Qj was required. I think Qj equals the first time derivative of rho_E, but I don't know how to express it.
2 Replies Last Post 7 feb 2012, 09:01 CET
Posted: 1 decade ago 7 feb 2012, 08:53 CET
If you want to create a variable that is the first time derivative you can use the "d"-operator. In your case you can define:
Qj = d(rho_E,t)
This operator is described further under "The differentation operators" in the help documentation.
If you want to create a variable that is the first time derivative you can use the "d"-operator. In your case you can define: Qj = d(rho_E,t) This operator is described further under "The differentation operators" in the help documentation.
Posted: 1 decade ago 7 feb 2012, 09:01 CET
Qj = d(rho_E,t)
Thanks a lot!
[QUOTE] If you want to create a variable that is the first time derivative you can use the "d"-operator. In your case you can define: Qj = d(rho_E,t) This operator is described further under "The differentation operators" in the help documentation. [/QUOTE] Thanks a lot!
