Transient Contact Modeling - Subdomain Separation
Posted 1 feb 2012, 11:47 GMT-5 Structural Mechanics 2 Replies
Problem: 2D Elastic cylinder resting on top of an 2D elastic plate, a transient force is applied to the bottom of the plate, pulling it down and releasing it (like a drum head). The sides of the plate are fixed. Watch resulting dynamics.
When I model this using a line of symmetry (not axisymmetric) the results look ok, the cylinder will detach from the plate and move off with constant speed, as it should (the cylinder should not undergo tension with the plate only compression).
But, when I model this is in simple 2D, no symmetry, there is always a point of contact between the cylinder and plate, even when the plate contracts back down, it 'pulls' the cylinder with it.
I have contact pairs between the cylinder and plate, and I turned off solving for contact pressure in the solver.
Any Ideas?
Thanks!
Chris
Any Ideas?
Thanks!
Chris
2 Replies Last Post 1 feb 2012, 12:55 GMT-5
