Programmatically ignore seam edges for cylinders
Posted 9 apr 2020, 05:58 GMT-4 LiveLink for MATLAB, Geometry, Mesh Version 5.5 0 Replies
I'm generating structures using a stochastic process. As a part of this structure I have multiple cylindrical geometries. I require a periodic mesh and have identified a key factor that causes meshing issues.
The seam lines on the cylinders are not periodic. COMSOLs mesh routine does not appear capable of on its own ignoring these seam lines and as such will attempt to build the mesh using these, and will therefore throw an error when it cannot. If I manually select these edges with an Ignore Edges virtual operation, I can mesh most of the structures. My problem is that I need to solve this programmatically in MATLAB. The surface edges are still important enough that I cannot make some sort of box selection for all edges that intersect the boundary.
The geometry is imported in .stp format. I've noticed that the setting "Remove redundant edges and vertices" does seem to remove some of the seams, but not enough.
Does anyone have any idea how I could solve this?
I've attached an example of a seam which I would need removed or ignored
Hello Daniel Fredriksson
