Robert Koslover
Certified Consultant
6 years ago
12 mar 2020, 11:21 GMT-4
Updated:
6 years ago
12 mar 2020, 11:23 GMT-4
Maybe. I don't think it is possible to give a reliable answer to your question without more information about your model, mesh, the physics being modeled, etc. I suggest that you post your model to the forum so that others may look at it and offer suggestions.
Alternatively, use a much finer mesh, and/or higher-order elements, and re-run your model. If the integrated value that you are talking about gets much closer to zero, then it may indeed be simply a result of numerical error.
6 years ago
12 mar 2020, 15:38 GMT-4
Indeed, I realize that I haven't given much information, but I did use a finer mesh and higher order elements and the integration approaches zero. Also, I noticed that the integration is greater in areas where the dependent variable varies more, so I think it is due to numerical errors.
Thank you,
Alex
Thank you,
Alex
