model aka hyperelastic_seal errors: non-integral power of negatic number
Posted 12 gen 2012, 12:52 GMT-5 Structural Mechanics Version 4.1 1 Reply
Hallo!
I am trying to model a 2D system similar to hyperelastic_seal. Unfortunatelly I get very often an error, especially when I want to make the mesh finer. If the mesh is coarse I got unsatisfactory results as two bodies are overlaping although there is a contact boundary. What should I change in the model. I attach both model file and a picture with plot of the any (but not ok) result. I got also similar error if I want compress the ring more than certain limit (both in case of predefined displacement or body load on the top body). What is the reason and solution/workaround?
Error log:
Segregated group 1
Attempt to evaluate non-integral power of negative number.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: mod1.solid.J@VDN$mod1.solid.Cl22
- Defined as: ((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5))))
- Variable: mod1.solid.Jel@VDN$mod1.solid.Cl22
- Defined as: (mod1.solid.FiiZZ*(mod1.solid.FiiYY*(mod1.solid.FiiXX*(((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5))))))))
- Variable: mod1.solid.II1@VDN$mod1.solid.Cl22
- Defined as: ((mod1.solid.I1*(((mod1.solid.FiiZZ*(mod1.solid.FiiYY*(mod1.solid.FiiXX*(((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5)))))))))*((-0.66666666666666663)*(mod1.solid.Jel^(-1.6666666666666665)))))+((mod1.solid.Jel^(-0.66666666666666663))*(((mod1.solid.FiiYY^2)))))
- Variable: mod1.solid.Ws@VDN$mod1.solid.Cl22
- Defined as: (mod1.solid.Ji*(((mod1.solid.C10*(((mod1.solid.I1*(((mod1.solid.FiiZZ*(mod1.solid.FiiYY*(mod1.solid.FiiXX*(((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5)))))))))*((-0.66666666666666663)*(mod1.solid.Jel^(-1.6666666666666665)))))+((mod1.solid.Jel^(-0.66666666666666663))*(((mod1.solid.FiiYY^2)))))))+(mod1.solid.C01*((((mod1.solid.Jel^(-1.3333333333333333))*((0.5*(((((mod1.solid.FiiYY^2)))*(mod1.solid.I1*2))-((mod1.solid.Cel22*2)*((mod1.solid.FiiYY^2)))))))+(mod1.solid.I2*(((mod1.solid.FiiZZ*(mod1.solid.FiiYY*(mod1.solid.FiiXX*(((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5)))))))))*((-1.3333333333333333)*(mod1.solid.Jel^(-2.333333333333333)))))))))+((0.5*mod1.solid.kappa)*(((mod1.solid.FiiZZ*(mod1.solid.FiiYY*(mod1.solid.FiiXX*(((mod1.solid.Cl33*mod1.solid.Cl11)*(0.5*((((mod1.solid.Cl11*mod1.solid.Cl22)-(mod1.solid.Cl12^2))*mod1.solid.Cl33)^(-0.5)))))))))*(((-1)+mod1.solid.Jel)*2)))))
Failed to evaluate variable.
- Variable: mod1.solid.SlY
- Defined as: (2*d(mod1.solid.Ws,mod1.solid.Cl22))
- Expression: d((-(mod1.solid.SlX*test(mod1.solid.elX)+2*mod1.solid.SlXY*test(mod1.solid.elXY)+mod1.solid.SlY*test(mod1.solid.elY)+mod1.solid.SlZ*test(mod1.solid.elZ))*mod1.solid.d)*(dvol),{test@3})
Thanks for replies.
Pawel
Error log:
Segregated group 1
- Function: ^
Thanks for replies.
Pawel
1 Reply Last Post 13 gen 2012, 09:21 GMT-5
