                                9 gen 2012, 09:46 GMT-5
                                                    please be noted that the same has been asked here:
www.comsol.eu/community/forums/general/thread/16052/
so it doesn't have anything to do with the version (I'm using 4.2), or the RAM or the hard disk(I too have plenty of all these).
Thanks again.
http://www.comsol.eu/community/forums/general/thread/16052/
Thanks again.
                                9 gen 2012, 10:19 GMT-5
have you checked that you are not in FAT32 which is limited to 2Gb file sizes, while for such long runs you can get easily tens of Gb temporary file ;)
                                9 gen 2012, 10:28 GMT-5
                                                    Hi again,
I don't know much about these, or even how to check it out, but the point is that the solution worked fine and was also dealt with before, and just after a while it stopped.
I'll describe it to you this way: today I came to the lab and looked at the solution for time=7*pi. then I changed time to 0, and error pops up; then I change it back to 7pi, and error pops up.
The hard disk has 26 GB of free space, if it matters~.
Could you direct me how to locate my temporary file folder?
Thank you,
Shoval
                            Hi again,
Thank you,
Shoval
                                9 gen 2012, 15:53 GMT-5
What I was referring to is the maximal size of a single file. Even if you have 100Gb free, if your file system is a fat32, still used by certain, paticularly for Linux/Windows mutual shearing, then your individual file size is limted to 2Gb (if I remember right). I had some of those problems on my D: disk that is still a fat32 because of Linux/Windows common shearing ;)
When I switched back (for the cratch and file storage) to my NTFS C: file format It worked OK.
But again this might not be your issu anyhow, just a potential case for file error trouble. As >5-8 Gb files are easily made with COMSOL
                                18 mar 2012, 08:19 GMT-4
                                                    Well here I am again, with the same problem. This time the computation was much bigger and longer, a parametric sweep which took in total more than 2 days. Can you tell me how to check if I am using a FAT32 and how to change that if I am? Should I contact COMSOL about it?
thanks again,
Shoval
thanks again,
Shoval
                                18 mar 2012, 11:35 GMT-4
                                                    If you are using Windows, right click on the drive and check properties.. You should should see the file type...
and to change to NTFS
support.microsoft.com/kb/307881
and to change to NTFS http://support.microsoft.com/kb/307881
                                25 apr 2012, 07:51 GMT-4
I'm also experiencing this problem. I checked my disk and its running on NTFS. I unchecked the option in comsol to save recovery files and the problem persists. Did anybody find a solution to this disk error?
Patricio Davila
Patricio Davila
