determination of velocity in a solid model
i am continuously getting an error after solving for the same. i have reffered many comsol pdfs but could not get any results for the same
1 Reply Last Post 6 gen 2012, 07:31 CET
Posted: 1 decade ago 6 gen 2012, 07:31 CET
if you are looking for (ut,vt,wt) the velocity vector you must use a time dependent solver, and depending on the version you have check the doc with respect to ut and uTIME if you use ALE check your help under "Derivatives of Dependent Variables" and other points therearound
Hi if you are looking for (ut,vt,wt) the velocity vector you must use a time dependent solver, and depending on the version you have check the doc with respect to ut and uTIME if you use ALE check your help under "Derivatives of Dependent Variables" and other points therearound -- Good luck Ivar
