units of time.
Dear Comsol forum,
when I use the argument "t", is it supposed that time is using the S.I., i.e. seconds?
Thanks in advance,
best regards.
1 Reply Last Post 16 dic 2011, 21:39 CET
Posted: 1 decade ago 16 dic 2011, 21:39 CET
indeed "t" by default is in seconds, if you need minutes, hours, days or years you can get it via the units multiplier, i.e. t[1/min] is a unit-less result expressed in minutes, just like td=t[1/d] is the day count ...
check the doc on the different time units
Hi indeed "t" by default is in seconds, if you need minutes, hours, days or years you can get it via the units multiplier, i.e. t[1/min] is a unit-less result expressed in minutes, just like td=t[1/d] is the day count ... check the doc on the different time units -- Good luck Ivar
