Global Evaluation Problem
Posted 15 dic 2011, 18:24 GMT-5 Results & Visualization, Structural Mechanics Version 4.2 1 Reply
I'm just trying to understand the syntax and procedure for using global variables and I keep running into problems with measuring the displacements. I defined a local variable, a point and a displacement direction. I then referenced this local variable with a global variable so it shows up in the global evaluation list. My global variable is mod1.(local variable). I get an error saying "Failed to Evaluate Variable" meanwhile, the point evaluation works great. Can someone explain what I am missing? The model is attached. Thanks.
1 Reply Last Post 19 dic 2011, 02:50 GMT-5
