Ambient thermal properties defined as variables
Hi users,
I'm studying a rather simple case (1d) where I have defined some heat and moisture transport with the use of PDEs. The reason I'm not using the predefined heat transfer modules is due to an additional source/sink term defined as an ODE.
What I need is to define the moisture content as a dirichlet boundary condition. Here, I would like to define it as a function of the ambient moisture content. So I need to extract the ambient moisture content (or relative humidity) from the weather file as a variable. Is this even possible?
Best, Mes
2 Replies Last Post 12 dic 2019, 03:07 GMT-5
Posted: 6 years ago 10 dic 2019, 09:16 GMT-5
Updated: 6 years ago 10 dic 2019, 04:16 GMT-5
Hello Mes,
If you have the ambient moisture at various times in a file, this is a job for an Interpolation Function, see e.g. the Reference Manual for COMSOL Multiphysics 5.5, page 322 and following. All manuals can be accessed from within the software via File > Help > Documentation. There are also many threads that discuss Interpolation functions in this Discussion Forum.
Jeff Hiller
Hello Mes, If you have the ambient moisture at various times in a file, this is a job for an Interpolation Function, see e.g. the Reference Manual for COMSOL Multiphysics 5.5, page 322 and following. All manuals can be accessed from within the software via File > Help > Documentation. There are also many threads that discuss Interpolation functions in this Discussion Forum. Best regards, Jeff
Posted: 6 years ago 12 dic 2019, 03:07 GMT-5
Thanks a lot :-)
Thanks a lot :-)
