3D Induction Motor Modelling
Posted 12 dic 2011, 17:36 GMT-5 Heat Transfer & Phase Change Version 4.2 6 Replies
Hi guys
I am trying to model a 3D three phase induction motor. I have attached the model. I went through previous discussions in this forum and have tried my best to build the model. The geometries are built in SolidWorks and the imported in comsol as different entities, which are then combined together to make a rotating part (rotor) and a stationary part (stator). The final geometry is assembled using 'form an assembly' while finalizing. There is a continuity pair defined in the boundary between the stator and rotor.
Some domains(stator slots and air) is using magnetic permeability defined in the material, where as some domains (stator and rotor core) are using the HB Curve, user defined. Two separate Ampere's Law have been used for these.
I have created a mesh in a way that I first created edges in the boundary between airpgar, rotor bars and the boundary of the stator near the airpap. then free triangular mesh is created in individual domains, which are then swept across the other side of the geometry. There are no error shown in the mesh.
Now my questions are listed as follows:
1) I have used external current density as a source. The three phase current density are marked with Ja, Jb and Jc, where '+ve' and '-ve' in the parenthesis means the inward and outward current respectively (similar to the cross and dot convention). But I read somewhere in this forum that simpling defining current density in a domain, without showing the flow of current is not valid in 3D. Is that true? If so, how should I define the flow? Can you please check the way I have defined the current density. Is it right? Do I need to connect the conductor at the end side?
2) I am doing a time-dependent study. To study the rotation in a 2D dimensional model was easy. But how to rotate the rotor in 3D? Shall I use the 'Moving Mesh'?. How to use that?
3)Until now, I have been doing it without considering the rotation. But in that case, the simulation begins but doesnot continue. Even simulating for 0.5 sec, it does not complete. It just begins, and remains as it is. The convergenge graphs even does not turn up!
I would be very very thankful for the help. Or atleast for an idea, how to proceed.
Best Regards
Best Regards
6 Replies Last Post 24 dic 2015, 03:38 GMT-5
