Eddy current simulation considering skin effects
Posted 11 dic 2011, 10:16 GMT-5 Low-Frequency Electromagnetics Version 4.2 3 Replies
My simulation goal is to simulate two solenoids with AC signal and 180 degree phase shift respectively, with the freq between 10MHz and 100MHz, and see the Lorrentz force of a Al plate over the two coils.
The method in official tutorial ppts I found is to add surface current condition on the coils with the excitation value of Current/(circle length).
However,the results are not good. the z component of electromagnetic force over the Al plate is too small, only 1/1000 of the real situation. The second is the r component of electromagnetic force. The force theoritically should point to the center of the system, and the whole force over the volume of Al plate should be 0 because the system is axis-symmetric. Actually, by integrating the r component of electromagnetic force what I got is a non-zero value. And I cannot understand why this happened.
3 Replies Last Post 12 dic 2011, 02:05 GMT-5
