2D surface plot of positive normal stress
Dear community,
I have an old model in V3.5a (quite big) where I need a special plot for a presentation. I calculated (2D axisymmetric) temperature and stresses and show normal radial stress, which is in a range between 69 and -200 MPa. As I want to have a closer look at the positive stresses, I tried to surface plot the expression "sr_maxi>0[MPa]". Unfortunately the surface plot is now dimensionless and shows a color range between 0 and 1. I need to illustrate the positive stresses as calculated, in MPa - how can I do that? Does anyone have an idea?
Thanks for your help,
Birgit
6 Replies Last Post 12 dic 2011, 22:08 CET
Posted: 1 decade ago 7 dic 2011, 15:35 CET
Birgit,
I think your expression must be sr_maxi*(sr_maxi>0)
This will plot all values > 0 and will plot 0 for negative values.
Maybe just defining a range for the plot would yield the same result?
Cheers
Edgar
Birgit, I think your expression must be sr_maxi*(sr_maxi>0) This will plot all values > 0 and will plot 0 for negative values. Maybe just defining a range for the plot would yield the same result? Cheers Edgar
Posted: 1 decade ago 8 dic 2011, 08:37 CET
Dear Edgar,
thanks for your reply.
Using the expression the square stresses [Pa^2] was shown, not what I wanted. But as usual, the simple things work best - just adjusting the range to 0-70 MPa gave me the needed picture. Thanks for the hint - I sometimes tend to think too complicated ;-)
Greetings, Birgit
Dear Edgar, thanks for your reply. Using the expression the square stresses [Pa^2] was shown, not what I wanted. But as usual, the simple things work best - just adjusting the range to 0-70 MPa gave me the needed picture. Thanks for the hint - I sometimes tend to think too complicated ;-) Greetings, Birgit
Posted: 1 decade ago 9 dic 2011, 07:08 CET
What about trying sr_maxi*(sr_maxi[1/Pa]>0) that should remove the extra Pa unit, and Boolean's work best dimension-less
Hi What about trying sr_maxi*(sr_maxi[1/Pa]>0) that should remove the extra Pa unit, and Boolean's work best dimension-less -- Good luck Ivar
Posted: 1 decade ago 12 dic 2011, 16:41 CET
Dear Ivar,
thanks also for your reply - I just tried your option and it worked - the stress is shown in MPa. Although the edition of the range has the advantage that everything below 0 is left blank and only stresses above 0 MPa is colored, whereas your suggestion already displays 0 MPa in dark blue. The option with everything blank besides >0 MPa is a bit clearer for looking at the overview.
Birgit
Dear Ivar, thanks also for your reply - I just tried your option and it worked - the stress is shown in MPa. Although the edition of the range has the advantage that everything below 0 is left blank and only stresses above 0 MPa is colored, whereas your suggestion already displays 0 MPa in dark blue. The option with everything blank besides >0 MPa is a bit clearer for looking at the overview. Best regards, Birgit
Posted: 1 decade ago 12 dic 2011, 16:47 CET
Hi Ivar,
I find it a little funny (or isn't it strange?) that a boolean expression returns a unit? I am wondering if this is consistent from mathematical point of view.
Cheers
Edgar
Hi Ivar, I find it a little funny (or isn't it strange?) that a boolean expression returns a unit? I am wondering if this is consistent from mathematical point of view. Cheers Edgar
Posted: 1 decade ago 12 dic 2011, 22:08 CET
Hi Edgar
I do agree with you, but that is the only explanation I can come to if there is a ^2 on the units, or there are something more on the line not shown. I havent rechecked, I mostly make my variables without units to enter a boolean expression, but in some fields its not possible, it flags an error, it seemsthat units are not accepted systematically and everywhere. Anyhoe I do not have 3.5 running anymore so I cannot check either ;)
Hi Edgar I do agree with you, but that is the only explanation I can come to if there is a ^2 on the units, or there are something more on the line not shown. I havent rechecked, I mostly make my variables without units to enter a boolean expression, but in some fields its not possible, it flags an error, it seemsthat units are not accepted systematically and everywhere. Anyhoe I do not have 3.5 running anymore so I cannot check either ;) -- Good luck Ivar
