Pawan Soami
COMSOL Employee
6 years ago
6 nov 2019, 06:16 CET
Updated:
6 years ago
6 nov 2019, 06:17 CET
Dear Hyunseok,
Each object/domain should be defined only in one physics, either in Multibody Dynamics or Solid Mechanics. In this case, the rotating object can be defined in the Multibody Dynamics interface and piezoelectric device can be defined in the Solid Mechanics interface.
Use Attachment node (in both physics) and Joint node (in MBD) to connect these two objects exist in two different physics.
Pawan Soami
Dear Hyunseok,
Pawan Soami
5 years ago
4 feb 2020, 14:46 CET
thank you for the reply.
This helped me to use both PZD and MBD at the same time.
But there was another problem.
I wanted to measure the current generated as my modeling rotates.
So I added an electrical circuit module under the same conditions and computed my modeling.
But this time it doesn't compute,
Only external I-terminal and resistor (10000000 ohm) were applied.
I don't understand why it doesn't work.
Is there a way to solve this problem?
Pawan Soami
COMSOL Employee
5 years ago
5 feb 2020, 07:12 CET
Dear Hyunseok,
Could you please share the exact error message what you are getting while adding Electrical Circuit interface in the model?
Pawan Soami
Dear Hyunseok,
Pawan Soami
5 years ago
5 feb 2020, 10:33 CET
Updated:
5 years ago
5 feb 2020, 10:43 CET
The error message is' Internal xmesh error. Failed to find model. '
When using adaptive mesh refinement, a 'maximum iteration reached' error occurs.
Alternatively, the convergence graph diverges and vibrates, and does not progress.
