how to plot the velocity profile between any two points in Comsol 4.2
Posted 24 nov 2011, 09:34 GMT-5 Version 4.2 8 Replies
want to know the same. No possibility to do such a plot?
Elmar
In the results section under data sets you need to create a 2D/3D Cut Line where you can specify the start and end points, then you can create a 1D plot a choose as a source the Cut Line you created before.
Cheers
thank you very much for this fast respond.
Have a nice day
I am going to plot additional cross sections parallel to the first one I defined. I checked Additional parallel line and entered the range. However when I click on plot icon to see the lines I only could see the first line and subsequently one velocity profile. How could I resolve the problem?
Since I want to take many cross sections I hate to do it manually for each one.
Thanks and regards,
when you add "additional lines" these appear on the positive "s" side, bit this "positive direction" might not be the one you expect, COMSOL has its own way ;) so try with negative values.
Normally in the later versions COMSOL show a small coordinate arrows to define +s and +t (s=along line, t transverse)
I tried it in your way, but still does not work. Any other recommendation?
saeid
You are right, negative distances is working. However, range is not working even when I input negative step size.
Thanks for your help,
Kind regards,
saeid
you need a "-range(0,0.1,1)" or a range(0,-0.1,-1) I would expect
the direction of "s" is defined by COMSOL so depending on the observation direction you need either + or - values, the coordinate arrow is there now in the plot to help you decide
